Old 04-18-2014, 04:05 PM   #21 (permalink)
TurnpikeCruiser's Avatar
Big Merc - '94 Ford F150 XL
The Cherry Bomb - '88 Mercury Grand Marquis LS
Luxoliner - '07 Mercury Grand Marquis LS
Team Panther
90 day: 23.63 mpg (US)
Also: are you also manually calculating your MPG on your fuel receipts? Because the UG isn't entirely accurate on a lean-burn engine.
At the moment yes I'm using just gas pump math. I know it's not the most accurate, but I'm doing what I can to help by always using the same fuel pump. The UltraGauge is only showing my consumption in the 40-45mpg range right now. An MPGuino may come down the road for the accuracy.
LuxoLiner - 2007 Mercury Grand Marquis LS
Old 06-16-2014, 02:28 PM   #22 (permalink)
Team Panther
Mirror Delete
I did this a little bit ago, just haven't had time to get on and share.
I removed the passenger side mirror and made a new block using scrap plastic I had around the house and then wrapped it all in duct tape to make a decent seal. Not as clean as it could be, but simple and effective!
