I don't know the part numbers, sorry. But in the table that leads this thread, you'll see that the speed sensors for the 5th and 6th gen civics are the same. And each submodel has the same one too. I got that info from the FSM manuals and several of the best established honda discussion boards.
EDIT: if you are referring to the speedo gear inside the tranny, then that's another matter. But i saw one guy measuring the 35mm and 40mm inner diameter speedo gears, the black and the white, and find their outter diameter exactly equal. Only the inner diameter varied. I would bet that's true of the fifth gen too, given how little seemed to change across the 5th and 6th gen trannys.
The VX has the white speedo gear.
James
