Old 04-28-2014, 01:48 PM   #56 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by tony_2018 View Post
Didn't see this reply. But the reason why I suggest this is to save yourself the headache and guessing game on what parts will fit. For the 96 model I still suggest you look for an HX model tranny.
Good advice to avoid guessing about part numbers for the gear swap, unless required. But there is no guessing involved in swapping a fifth gen trans onto a sixth gen engine. It has been done countless times as a plain bolt-on, without any mods. I did it: a 1993 CX onto my 1998 D16 engine. Seriously, if taller gearing is the point the biggest bang for the simplest swap is the 1992-1995 VX/CX transmission. Check the table that leads this thread. The fifth gear is the same, VX/CX - HX, but the FD is far taller on the VX/CX. Just saying... it's true.
vrmouseyd15b (04-29-2014)
