Old 04-28-2014, 04:30 PM   #325 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Quezacotl View Post
I received the boards, and the prototype works perfectly
Now it has USBasp integrated, and it works.
But now i have one questions:
-How to save the system time once i have set it? If i press left+right it says "time NOT set".
-And is there any usage for 5-position switch yet?
Here's my new board
That's a nice looking board!
To save the system time once you set it, press and hold the center button. I tried to make that common across all of the options that require setting values. Press the center button to change the value, and press and hold the center button to set the changed value.
The 5-position switch is partially supported; however, I have yet to document it. The 5-position switch is not really compatible with the traditional 3-button setup, either.
I have some time coming up for rest and relaxation - I'll probably do some more real work with the MPGuino code here.
