Old 04-29-2014, 03:31 PM   #11 (permalink)
tony_2018
Which is why I questioned how did he get a cel for an o2 sensor if he said getting getting codes were a pain. OP, create a video of the blinking cel light. Also how are you getting everything wired up if this is all going into an obd1 car? Is the egr sensor, egr control solenoid and vtec wires hooked up properly?
EDIT: confirm the pinouts so I can see if you have everything properly. I have a feeling either the o2 wire was hooked up to the wrong pin or all of the above has not been correctly pin.
