Old 04-30-2014, 05:07 PM   #192 (permalink)
NeilBlanchard
I have had this happen several times. I have a workaround and a suggestion.
Originally Posted by More air less fuel View Post
I just spent two hours writing all about a test that I did today. It disappeared while submitting! WTF!
The workaround is to open a second tab on the EM forum and then click Recent Posts, and if your browser (I use Firefox) has a timed auto-reload option, set that to 5 minutes or slightly longer, and that will reset the inactivity timer. If you don't have this plugin, then you can do this manually.
The suggestion is to Control-A (select all) and Control-C (copy to the clipboard) the entire post *before* you click Submit Reply. If you have not been using the second tab to refresh the timer, then you can go to a second tab now and check if you are still logged in, and sign (back) in if need be, before clicking Submit Reply.
Xist (04-30-2014)
