Old 04-30-2014, 09:33 PM   #29 (permalink)
vrmouseyd15b
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
Originally Posted by cbaber View Post
No EGR? BTW, the D15B 3 stages run the 1-wire o2 sensor, the 4-wire is a heated O2 sensor. It will work if it's wired correctly, the difference is the heating element of the 4-wire and running the P2J-003 it's probably not being utilized unless the heating is not ECU controlled.
maybe that's what TK should try: pin a 4-wire o2 to the ecu. cheaper than a ecu, I'm sure.
