Old 04-30-2014, 11:11 PM   #221 (permalink)
racprops
At this point I have all three, A Scan Gauge II, a MPGunio, AND a Zemco Milage computer...
The scan gauge is fooled if I tweak the PCM so I use it for other things...the MPGunio currently IS my MPG readout until I find time to try a couple of other things... then I plan on hooking up the Zemco.
Currently I set aside working on MPG and did some customizing to the interior by adding a Mustang Gauge Cluster, a center console with floor shifter and a custom dash to console setup.
Rich
PS that is a 2000 Mercury Grand Marquis, which will get up to 30 MPG at 65 MPH.
Originally Posted by TheTestPilot View Post
ok , I now see your problem ,so do you want to use the mpGuino ,as the measuring device ,or you want a voltage output vs flow type sensor & read it with something else.
My Idea , was the flow sensor could be connected to The MPGuino without messing with the standard code .
