Originally Posted by MetroMPG
How about 40%?
I loaned him my ScanGauge and set the engine size. We were really impressed with the early numbers he was getting, but became progressively more skeptical as the gas gauge approached E.
What all do you calibrate on the SGII?
On an Ultragauge, it needs engine size, and you calibrate distance
and fuel consumption. If I have it set for one car that is on one end of the ranges and move it to a car that would be on the opposite end of each range I could see it maybe being that far off, even if I change the engine displacement.
