Thread: Dual Vtec CRV
Old 05-03-2014, 05:07 PM   #17 (permalink)
tony_2018
Originally Posted by cbaber View Post
Horsepower isn't really the concern, it's the torque and weight. The B20 puts out 130 ft/lbs while the D15B is barely hitting 100 ft/lb, and it peaks near 5300 RPM. The CR-V weights nearly 1000 lbs more than the Civic's the D15B was designed for. So the increased weight along with decreased torque equals something that is neither fun to drive or economical, even with lean burn.
If he does decide to turbo it he could probably benefit from it. Boosting these d-series motor, if tuned properly, they can gain mpg from it. It would definitely be a fun project and something to confirm and prove as the engine bay is almost similar to the ej8. The only thing I worry about that needs custom fab is the rear t-bracket. Engine harness is basicly plug and play so if he decided to go obd1 with tuning options he is good to go.
