F1 and some other race engines need to be pre warmed because the tolerances are so much tighter than street engines that if they were cold started the engines would seize from oil not being able to flow through the tight spaces.
Large ship engines are pre warmed too.
The ship engines and race cars normally use accumulators to move the oil before start up.
Warm starting seems to be more important to wear prevention than pre lube.
Also using block a heater has proven to save fuel.
Dont use 0w or 5w-20 oil unless you are looking for more engine wear.
There is a 1% fuel economy difference between 5w-20 and 10w-30 weight oil. The wear difference between the two is much more than 1%.
