Old 05-04-2014, 11:18 AM   #6518 (permalink)
jedsmd
PLUGnGO
jedsmd's Avatar
Originally Posted by duncan View Post
....Would it be possible to have an output that I could take to an LED on my dash that would tell me if the controller is downgrading due to temperature?
Duncan
This is the solution I found for monitoring controller temperature:
White Universal Car Motor 20LED Analog 52mm Digital Water Temp Temperature Gauge | eBay
There are lots of automotive temperature gauges on Ebay, I picked this one because it works all the way down to 20 degC most of them only go down to 40.
To install I intend to drill a hole in the controller base plate near the IGBTs to fit the sensor tip.
