You could flip the on off switch and make it gas only. It's pretty simple, I would have taken some pictures when I did an Insight IMA swap last night. Pull up the rug, take out two 10mm bolts, red cap, flip the switch.
On the highway it would probably be more efficient without the battery, to be honest. They're heavy.
EDIT: There is a LITTLE more to it, please check post below.
