Old 05-05-2014, 01:43 PM   #20 (permalink)
darcane
darcane's Avatar
Ouch, that sucks! Hope you didn't get hurt.
Originally Posted by deejaaa View Post
thanks to the DVR i might have a case with the insurance co.
not much damage as i thought but there was some sheet metal bent around the light.
<snip>
replaced the lens and used a hammer to get it to fit.
I assume this means you are just making repairs on your own? If so, make sure you pull the bumper cover off and check out the actual bumper. There should be a foam crush pad on the steel bumper and the bumper mounts are designed to collapse. If either of these are damaged, a second impact to the same spot would transmit far more energy to you and can cause serious injuries.
A coworker did just this and the second crash, which was fairly minor, caused a herniated disc and required several surgeries.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
