Old 05-05-2014, 04:35 PM   #2 (permalink)
cbaber
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
Trouble code 22 is for the oil pressure switch, not the VTEC solenoid. The actual solenoid is code 21. OBD1 Trouble Codes - Honda-Tech
First thing check the oil level. The thing is, the pressure switch or the VTEC solenoid is not going to cause the symptoms you describe. It sounds like EGR or O2 sensor to me, even though you don't have a CEL. Try unplugging your primary O2 sensor. Does the sputtering go away?
1998 Honda Civic HX - My Project Thread
