Old 01-05-2008, 04:30 PM   #2 (permalink)
MetroMPG
90 day: 49.35 mpg (US)
Beaver replied...
Originally Posted by Beaver
Yes, I did a quick compression check, and the cylinders were low (@150), but about equal. The check was done on a stone cold engine however, so I'd expect low readings. It's a high mileage engine at 158,000 miles. I think it may be idling too low, as you mentioned, but isn't the idle speed set by the ECU? If not I could pick it up a couple of hundred rpm's and that would go a long way toward smoothing it out.
I haven't ever had a 3 cyl before, so I have nothing to compare it to except 4,6 & 8's.
I have to take it out for a short drive in a little while, and I'll ty to note whether or not it feels rough under acceleration or at speed. Thanks again, and I'll put some cars in the "garage."
