Originally Posted by NachtRitter
Puzzled by this... isn't that what the EPA sticker on the car tells you? What the FE of the car is based on a set of common tests (applied equally to all cars) as specified by the EPA?
Yup.
A common set of tests that is either woefully pessimistic (for us) or woefully unrealistic (for people on the other end of the bell curve).
The problem is, EPA auditing is spotty enough that a lot of cars slip through the cracks with numbers that are not comparable to other cars on the same driving cycle. Per-variant testing is expensive, but it's probably time the EPA (or some independent third-party) took over testing duties from the manufacturers.
