Old 05-10-2014, 02:32 PM   #17 (permalink)
serialk11r
My take on the clutch thing is if you press in the clutch, your clutch bearing might wear a little faster but clutches need to be replaced anyways and it's usually the friction material that goes not the bearing. Shifting in and out of gear will put extra wear on the synchros which are much harder to replace than the clutch.
