07-09-2008, 02:06 PM
#77 (permalink)
Thanks for the info, guys. More living & learning.
This morning I glassed the first outside layer over the resin skim coat on the cardboard. I'll do the 2nd layer this evening & get some pics. It's apparent that I'm also going to add some structure to reinforce the trailing edge of the top portion so it holds the right shape.
The more I do, the more I realize there will be a lot of "finishing" work to make it look nice - ie. a skim coat of bondo, and lots of sanding to level out the surface.
