The measurements were done in the garage where the concrete is perfectly level side to side, and the result matches my previous observation of the tread.
Originally Posted by johnlvs2run
IThe front driver side tire has a positive camber, about a 1/4 inch of the inside tread is hardly worn, and the outside of the tread sets down slightly before the inside of the tread.
The steering is fine, so I'm thinking to get 4 bolts and add 2 washers to each one in the back, which would bring the back camber down 1 degree on each side, instead of a camber kit. However I still need to measure the toe in the meantime.
