05-11-2014, 08:58 PM
100 km per charge - I assume you're going with a fairly large lithium pack then. 4-6 hr recharge would mean a very beefy charger as well (220v).
Pretty much the only part on the ForkenSwift that you could use (since you'd also be going with much higher voltage) would be the motor.
