Old 05-12-2014, 01:33 PM   #5 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Probably still an ABS issue if they replaced it. Or maybe ABS plus crappy alignment job.
Aslo possible: ABS & crappy alignment & an oopsy while they were changing out the ABS (wire shorting, pulled a vacuum line loose, etc. . . .)
If it's not straight-up ABS failure, you'll see it in tire wear or eventually it'll throw a code unless . . . . check the parking brake, if it's pulled (or pushed) one notch in, it'll kill your gas mileage and it'll feel like you have no power, and one notch might not cause the brake light to pop on
Does it feel grabby at all when you brake?
