Does it steer different than before? Pull the ABS fuse and see if that makes any difference. I don't think ABS should drag during normal driving, but I could see a malfunctioning ESC (electronic stability control) causing it to apply the brakes. Could try to pull that fuse or turn it off if possible.
I think they added some toe in to make it track straighter. Do you have the alignment chart to show the before and after numbers.
