I've been checking the error only happens if disabled (# define ArduinoMega2560 true) with (# define useChryslerMAPCorrection true) active, if you enable (# define ArduinoMega2560 true) already fails to make the mistake.
has error
//#Define true useChryslerMAPCorrection
no error
no error
the error is:c:/program files/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr6/crtm2560.o: In function `__vector_default':
(.vectors+0x4): relocation truncated to fit: R_AVR_13_PCREL against symbol `__vector_1' defined in .text.__vector_1 section in sketch_may13a.cpp.o
Thank you
José Rodrigues
