Originally Posted by XYZ
Does the test cost $35?
By the time you are testing the oil, it is dirty and of questionable usefulness, right? Wouldn't it be more economical simply to change the oil?
Guess you failed to read the info provided by the report???????
1 gives feed back on engine wear....kinda important
2 show if you should run the current oil longer or run the next change longer also valuable information
Ex: if you oil is still good at 5k then running to 8k each time just saved you the cost of 1 change every 2 times
I ran my 2002 Infiniti q45 to 270,000 miles based primarily on the reports received from Blackstone at the 150k and 190k mile markers
