tvago thank you so much on your hard work again on the code. The programmer has arrived today so i will pick it up today. I have jellybean board with atmel 328 chip. Which code you think i should try first. 191 or 192. I see error relating to 2560 board which i don't have, What version of Arduino IDE are you using? 1.05? The one you referred as stable?
