Old 05-14-2014, 04:57 PM   #359 (permalink)
josemapiro
Originally Posted by t vago View Post
This issue appears to be related to the Arduino compiler itself. Apparently, there's some sort of updated toolchain, available at the bottom of this bug report: https://github.com/arduino/Arduino/issues/1071
I have not myself been able to duplicate the issue, but I am using a stable form of the Arduino IDE.
Okay, maybe this is wrong, I'll install a newer version may have the problem solved.
tvago thank you so much on your hard work again on the code. The programmer has arrived today so i will pick it up today. I have jellybean board with atmel 328 chip. Which code you think i should try first. 191 or 192. I see error relating to 2560 board which i don't have, What version of Arduino IDE are you using? 1.05? The one you referred as stable?
You can use the latest version because the error is perhaps the compiler, but also does not affect most people, I have to run smoothly.
The error does not affect me, just communicated that can be solved, but it seems the problem is in the compiler.
Test without fear and let here your opinion.
Thank you
José Rodrigues
The Following User Says Thank You to josemapiro For This Useful Post:
stewie (05-15-2014)
