Old 05-14-2014, 09:25 PM   #18 (permalink)
Superfuelgero
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Originally Posted by greasemonkee View Post
Does anyone know if it is possible to add the PA sensor to the P07-G01 euro ecu's or is it written into the code?
It might be possible, since the LB cars were so low o volume that it wouldn't make sense to have another board design. When I get a chance I'll grab mine and look (since I have 3). Its more than likely a signal modifier in series with the map sensor signal. There is probably a shunt to bypass this part of the circuit.
Update on my setup: switched to the UK unit (from the lithuanian version), feels less aggressive in both timing and LB window. Odd since they are both G02's, but with different IC's.
Shooting for 600 miles of range at 65-70 mph out of a vx.
