Originally Posted by BrandonMods
Very nicely done! For your indicator light for the fan indicator light, where did you connect the leads for it? At the fuse block or did you just hook the circuit in parallel?
Thank you!
I stuck one lead alongside the appropriate blade of the radiator fan relay, and put the other lead to the exposed frame next to the light behind the plastic panel.
