Originally Posted by nemo
When you changed out the bent rims were the tire replaced also or were your tires put on the replacement rims? If your tires were your used it is still possible that you have one or more bad tires. Impact enough to damage the rims may have damaged the tire(s) It is unfortunate that you were unable to swap out the rims and tires from one of the other cars that would have gone a long way to helping you trouble shoot the problem.
Did placing gauge under the seat work? Make sure it turns off before doing so. Mine randomly stays on and turning the key on then off is needed to get it to shut down.
Still the same tires. I'm gonna do the rotors, brakes and tires when I get the money, hopefully that fixes it. If not... Well I will deal with that if it happens.
As for UG under the seat idk yet, I get off at night so yea.
