Originally Posted by basjoos
Would this table cover vinyl sheet be stiff enough not to flap and flutter in the wind? Once a surface starts fluttering, its surface drag goes way up (think of when you hold a fluttering flag up to the wind compared with holding the same size rigid sheet to the same wind).
I think so, but to be safe you could go for a thicker one than I used on my front grille. Another possibility is to attach coroplast to the areas that aren't secured to the car; the coroplast would provide rigidity while the vinyl sheet gives you an easy mounting option.
