Old 05-17-2014, 10:41 PM   #11 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Pretty Bold to go with a full boat tail on a 2010 Kudos!
The Following User Says Thank You to mikeyjd For This Useful Post:
Rishar (05-17-2014)
Old 05-17-2014, 11:04 PM   #12 (permalink)
What did I just do?!
Rishar's Avatar
Angry Bird - '10 Toyota Prius
90 day: 62.27 mpg (US)
After Basjoos suggestion of moving the template forward and NeilBlanchard's suggestion to do some tuft testing to make sure the current shape was aerodynamic to continue the current shape, I believe this is more what I'll end up with.
Shouldn't be too hard right? ...
Old 05-17-2014, 11:10 PM   #13 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
A tow hitch would provide a weight bearing attachment point plus some towing ability.
I have a somewhat aerodynamic tow hitch mounted on the Beetle , it is the round tube design type ,much like the one in the photo
Save gas
The Following User Says Thank You to ecomodded For This Useful Post:
Rishar (05-17-2014)
Old 05-17-2014, 11:33 PM   #14 (permalink)
Rishar's Avatar
Attachment 15023
That's a thought! I'm going to be looking under the bumper for attach points as well. The bigger things though require more time than I usually have . I have to use this vehicle for work. On that note...I'm really not sure how my employer would feel about me using a aero-modded vehicle as a delivery vehicle...
...eh...what are they going to do...fire me? Pfffft...just give me more time to work on it.
The Following User Says Thank You to Rishar For This Useful Post:
mikeyjd (05-18-2014)
Old 05-18-2014, 12:28 AM   #15 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
Easier to ask for forgiveness than permission
Old 05-18-2014, 09:21 AM   #16 (permalink)
Originally Posted by basjoos View Post
Would this table cover vinyl sheet be stiff enough not to flap and flutter in the wind? Once a surface starts fluttering, its surface drag goes way up (think of when you hold a fluttering flag up to the wind compared with holding the same size rigid sheet to the same wind).
I think so, but to be safe you could go for a thicker one than I used on my front grille. Another possibility is to attach coroplast to the areas that aren't secured to the car; the coroplast would provide rigidity while the vinyl sheet gives you an easy mounting option.
Old 05-18-2014, 12:27 PM   #17 (permalink)
Given a vehicle length about 14 1/2ft; you're showing an overall length about 21 1/2ft. I think that's longer than a parking space. (20ft?)
Also the Template assumes a half-circular cross section. If you look at it in plan, the length may be different. I got a similar result for my car and started looking for ways to truncate it.
The one on the left would use a Coanda nozzle to virtually shorten the length.
Rishar (05-18-2014)
Old 05-18-2014, 01:56 PM   #18 (permalink)
Rishar's Avatar
*nod* Yes, I'd be working up from the bottom as well. I want to end up with something more along these lines when I'm done. Otherwise, like you said, I'd have some length issues.
The other thing I really like in this picture is the rear view camera on the side. That would be my preferred setup if I can get away with it.
Old 05-19-2014, 01:38 AM   #19 (permalink)
So your goal is perfection?
I saw a concept car where the rear view screens were sunk into recesses in the doors so there wouldn't be any glare on them.
Rishar (05-19-2014)
Old 05-19-2014, 01:44 AM   #20 (permalink)
Rishar's Avatar
Perfection....great....now all I can think about is going with a borg theme.
That is pretty cool. It's too bad most of these concept cars don't come out as is. They look so great and then they change them to what they think will sell.
I want my thorium powered car now kthnx
