Old 05-19-2014, 09:47 AM   #294 (permalink)
user removed
On the subject of crosswind instability, my idea is to have a group of "gills" in the remaining part of the rear end, the opposite of louvers you see on hoods of the hot rods that protrude above the level of the sheet metal, I think they should protrude below the surface of the sheet metal. Air intake for the radiator probably from the bottom right in front of the engine, with a baffle to deflect water and debris down and away from the radiator opening. I'm still open to thoughts and suggestions about this. The bike had a temperature gauge so I should be able to monitor cooling system temperatures and control the cooling air inlet size to minimize air flow disruption while not risking overheating. Radiator heat will also be utilized for cabin heat in cold temperatures, while Catalytic converter heat will provide preheating of the engines intake air.
regards
Mech
aerohead (05-19-2014)
