Originally Posted by aerohead
It would be good to locate a Pontiac Trans Am Firebird or Corvette to inspect their system
*There needs to be a deep air dam directly below the inlet at 'B'.
*The 'belly' of the nose leading to the inlet opening should be even with the top of the air dam.There must be a section of 'belly' from your stagnation point leading towards the inlet.You can't just have the angled panel.It will cause complete flow separation with no re-attachment anywhere near the inlet.'A' will need to be a small nose section to allow the flow to get setup for the inlet.
*Flow 'C' will travel below your new nose,curve gently upwards along a large radius'd duct wall,contained within side walls.
*The opening leads to an airtight duct leading up to the radiator core,aided by the new air dam below.
Aero is right, the trans ams, fieros all had an air dam there. I have an opening similar to you, it won't do anything. Need some high pressure to encourage it to go through the radiator. You can reduce this by increasing the low (much like the trans am).
