Originally Posted by Baltothewolf
Finally found out what the problem is. The axle is bad. Not to much to fix, parts+labor is 185. I had the mechanic I take my car to put it on a stand and run it @70mph and you could clearly see the axle vibrating.
I've had an axle break on me before... after a night of drag racing and plenty of wheel hop launching at the track, the drive home was odd. It vibrated like CRAZY when I would accelerate, but not when just cruising or anything else. Sure enough, that axle limped me home.
Glad you found your issue!
