I don't think it is more than what I need it is likely just right. I figured I would start with mild steel first then transition into aluminum.
The machine is a 250amp AC/DC with enough options where I won't have to buy another machine unless I start to do it professionally.
That is just how I buy things, so they will grow with me and not hinder or limit my ambitions. In the land of welders most will say buy the most you can afford because you will likely regret going small later. I could have used a welder so many times in the last three years for other projects on my ninja 250. To me it is a long term purchase.
I forgot to include an argon tank in the mix which will likely run me $350ish
For this project I likely will not end up welding aluminum but I will likely replace components of this project later with aluminum to save weight as I bring up my skill level. Also I should note I don't need this to complete my project, it is a want not a need, as I can find a local welder to weld up my pieces for me.
And I am sure with a little bit more thought I could figure out a way to do the project without welding even that part. In fact I just thought of one
A very simple modification too, just make it all one piece instead of a two part bracket system. Of course this assumes a single 1/8 piece of mild steel could live up to the stresses without cross bracing. I will run the idea past Vetter.
