Old 05-22-2014, 11:56 AM   #176 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Eastwood View Post
Is that more coroplast? What do you use to cut it?
I have found a set of offset Wiss tin snips works best for me.
Grinders & Cutoff | Shears, Scissors & Snips | Wiss M6R Metalmaster Offset Left Cut Aviation Snip | B322458 - GlobalIndustrial.com
Sorry to hijack momentarily.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
