Old 05-23-2014, 12:28 PM   #28 (permalink)
oil pan 4
Solar road way?
You are kidding right.
First of all they can't build a regular road that doesn't start to break down after just a few years. Then you are going to integrate solar cells more fragile than a potato chip into the road surface and drive 80,000 pound trucks on them. That sounds like a terrible idea.
Have you ever dont any road work? Its miserable work, I have gone out to do repairs on their machinery and you wouldn't believe all the deep gouges, divits and nicks the road way accumulate from tires falling off, trailer tires blowing out and the driver just keeps going the tire shreads apart and then they ride it on the steel rim to the next exit, items falling off trailers, junk getting ran over hung up under then dragged under vehicles. Then when a tractor trailer tire blows do you have any idea how much force the tread belt swings around with? Hitting the ground with every rotation.
Thats just what we need, a road that suffers millions of dollars in damage and stays closed for who knows how long after a tire blow out or vehicle fire.
Its starting to sound like a bad idea, but wait there's more.
In addition to all that, any where up north that sees deep frost has compression ridges, these compression ridges shatter concrete and asphalt with ease. Also any where up north that sees daily freeze thaw cycles has roads that only last a few years before they start to look like a mosaic. Dont for get most of the roads in the US see a snow plow and road salt most winters.
Aside from being an epic waste of money on an unimaginable scale that wont work in most places I see no problem with it.
Just putting regular roof top solar panels or "the solar roofing shingle" on houses seems like a much better idea. At least then 40 ton trucks are not being driven on them constantly.
I would rather see individual home and property owners controling power generation rather than the government.
