Old 05-24-2014, 06:08 PM   #13 (permalink)
vrmouseyd15b
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
a little late,
but on the p2j ecu's, I'm pretty sure pin A30 was the switched ground for the lean burn indicator (econo light).
This is a switched ground, meaning you need to bring 12v power (prefferably on with the ignition, off otherwise) to one side of your indicator light, and run the ground wire to pin A30 on the p2j ecu.
I made mine in my 96 civic lx with a d15b 3 stage vtec and lx manual tranny and a p2j-j62ecu
80mph/3200rpm is about the highest speed/rpm I can run in lean burn mode!!
