Old 09-24-2011, 03:02 PM   #11 (permalink)
Joe1234's Avatar
Which indicator is the most correct? The o2 voltage or the vacuum?
Old 03-02-2013, 06:13 PM   #12 (permalink)
Gasser - '94 Honda Civic VX
most correct? the MPGuino, the DVOM will only let you know what lambda your at, the vacuum gauge, how much load you have on the engine.
Vacuum gauge: help you teach you and your foot to drive more economically
DVOM: Tells you when your in lean burn, and open loop ONLY
with their powers combined you will have the tools you need to drive better, but you wont have measurable data until you get to the gas pump, and you rely on your odometer (which is much less accurate than a calibrated MPGuino) With a MPGuino you will be able to find what speeds your most efficient at.
I have yet to see mechanical odometer closer than 2% error.
IMO the DVOM is not worth installing, and the vacuum gauge is questionable in its usefulness once you have a MPGuino.
Nobody on this forum with argue, a MPGuino, scangauge, or ultragauge will pay for itself.
Old 05-24-2014, 06:08 PM   #13 (permalink)
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
a little late,
but on the p2j ecu's, I'm pretty sure pin A30 was the switched ground for the lean burn indicator (econo light).
This is a switched ground, meaning you need to bring 12v power (prefferably on with the ignition, off otherwise) to one side of your indicator light, and run the ground wire to pin A30 on the p2j ecu.
I made mine in my 96 civic lx with a d15b 3 stage vtec and lx manual tranny and a p2j-j62ecu
80mph/3200rpm is about the highest speed/rpm I can run in lean burn mode!!
