Originally Posted by EchoTech
Does anyone maintain the pressure difference between the front and rear tires, e.g. placard says 30psi front, 34 psi rear when increasing pressure? Does it make a difference?
I do, my car is rear heavy and has bigger rear tires so I maintain higher pressure in the rear. I think it's a good idea since you are allowing relatively more compliance where it's lighter, and you're changing the handling less as you're not effectively stiffening up one end of the car.
