When you say to use a recirculating pump are you running the water through anything to cool it? Like a heater core with fans and a power supply?
EDIT: Looking at other peoples DIY torch cooler projects and it seems to make sense to simply build my own. It seems many don't need heat exchangers and it would be really easy to build one.
I once built my own watercooling box out of acrylic for my PC which had two ford 6" heater cores in it with 4 fans. It matched my acrylic box at the time for my PC but was pretty loud. I still have the pump but I bet the 900gmh would be a bit much for a torch lol
