Old 05-30-2014, 09:36 PM   #112 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
wrong with capital R
When you add a hydrogen cell to a vehicle the vehicle's O2 sensors sense the change and dump in more fuel to compensate to get you right back to 14:1 as it's designed.
Hydrogen burns with oxygen to form water vapour. In other words, the cars ECU will lean out the intake mixture because some of the gasoline required will be displaced with hydrogen to form the proper stoichiometric ratio. There is no oxygen "hanging out" in the exhaust when you inject hydrogen into the motor. In other words your own bogus science already is proving your philosophy wrong.
ok
so
this is NOT how it works
02 sensors do not see oxygen
so theory of hoaxes regarding extra oxygen in the exhaust causing something is complete and utter
blarney
02 sensors or more correctly Lambda sensors
see and measure the presence of
combustibles ,
any combustibles
including hydrogen
in the exhaust
so
if some pudding head is attempting to describe why HHO does not work
(in newer systems with feedback from 02 / lambda / AFR sensors)
and he or she starts talking about
lean condition caused by adding more combustibles or 02 to the equation
then that pudding head is fibbing or ignorant or
attempting to deceive the reader or audience
and Lambda or
stoich is
14.69 to 1 NOT 14 to 1
i will add none of these crack smokers have contacted myself about testing their systems
color me surprised
offer stands
thank me very much
spank you pudding heads
and
all
newer systems with AFR sensors are capable of operating in "lean burn"
or leaner than 14.69 to 1
