Old 06-01-2014, 02:53 PM   #62 (permalink)
Davo53209@yahoo.com
I just cleaned out the EGR valve, whereas I plan to to adjust the ignition timing next.
In the event that I'm still not gaining much improvement, do you think that it would be excessive to replace the PCV valve, the fuel injectors, do a valve job, or replace all of the vacuum lines. After all, they are twenty years old.
