Old 06-01-2014, 04:15 PM   #114 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
Originally Posted by bobdbilder View Post
The problem that I see is energy used for the process.
That is only the beginning of the problems. I've only heard one remotely coherent theory on it and it is still plagued with problems.
If nobody is succeeding at it then they all must be doing something wrong?
If you are thinking simple retrofit, then you are severely misguided. Just hook that solar panel up to your hybrid traction battery otherwise.
