Old 06-02-2014, 12:52 PM   #11 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
With today's new aerosol technology you can do this. It won't be as strong but will work. The key is to not let fuel get on it and set for more a few minutes.
The other down side is the size of the paint job. If the stripe is only 12" or less wide then you should be OK. Any bigger the you will have mottling (tiger striping) issues.
Pressure Gradient Force
The Positive Side of the Number Line
