Old 06-02-2014, 11:04 PM   #25 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
don't use the UG for mpg figures. only way is by gallons/miles. mine might show avg mpg '59' but when calculated comes out more. mph is different on mine and i would drive myself crazy to figure out which was closer; speedo, gps or UG. now i don't care. i set my cruise to 2000 rpm and roll with it. but i will adjust speeds if there is a head wind, rain or a rough surface asphalt road. i have mine mounted to my ac vents, soldered heavy copper wire together, bent to shape, covered some of it with shrink tubing, this way i can reach the back buttons without having to remove the gauge.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
