glueing the vinyl on the wheels
The vinyl comes with an adhesive already on the back. All you need to do is remove the white backer material and spray some soapy water on the wheel and the back of the vinyl to keep it from sticking to itself or the wheel were you didn't want it to.
When it dries (over night) it will not come off easily. I know because I had to remove my first botched attempt. It also left some adhesive residue which came off with a little brake cleaner fluid on a rag (do not spray it on the Wheel!!)
Time will tell, but I think this 3 mil vinyl is very durable. It is also used to "wrap" entire cars.
