Old 06-04-2014, 02:53 PM   #141 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Originally Posted by johnlvs2run View Post
Thanks for the details of your mod.
The vinyl has advantages compared to coroplast, more streamlined, no bulge, easier to get to valves and wheel bolts, no plastic ties. I'm curious how well the vinyl will keep sticking, and am interested to try it on mine, along with wheel gap fillers for all wheels.
Why not glue the vynil onto the rims?
Old 06-04-2014, 04:04 PM   #142 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Isn't that how it's done; the vinyl sticks to the rims?
Old 06-04-2014, 04:56 PM   #143 (permalink)
Liberty Lover
j12piprius's Avatar
wheelhouse departure radii
The donkey CRX, thanks much for posting your mods.
If I might ask, what screws did you use to attach the radii to the body?
There is still a large gap above the tire; is that to leave room for bouncing on turns?
Old 06-04-2014, 09:07 PM   #144 (permalink)
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
glueing the vinyl on the wheels
The vinyl comes with an adhesive already on the back. All you need to do is remove the white backer material and spray some soapy water on the wheel and the back of the vinyl to keep it from sticking to itself or the wheel were you didn't want it to.
When it dries (over night) it will not come off easily. I know because I had to remove my first botched attempt. It also left some adhesive residue which came off with a little brake cleaner fluid on a rag (do not spray it on the Wheel!!)
Time will tell, but I think this 3 mil vinyl is very durable. It is also used to "wrap" entire cars.
The Following 4 Users Say Thank You to The donkey CRX For This Useful Post:
accord_minded (08-09-2014), mikeyjd (01-07-2015), Natalya (06-20-2017), OG VX (12-15-2014)
Old 06-04-2014, 09:16 PM   #145 (permalink)
Gen-1 Insights
Reply to John
I used #6 stainless steel counter sunk philips head screws. I always "treat" any hole drilled in the body with rust proof paint on a small artist brush and also put silicone chalk on the screw.
It may not look like it, but the radii is tight to the rear of the wheel well, It only needs to draw the engine compartment hot air at the right of the radii out and into the air stream along side the car. I hope I understood your question.
The Following 2 Users Say Thank You to The donkey CRX For This Useful Post:
j12piprius (06-04-2014), mikeyjd (01-07-2015)
Old 06-04-2014, 09:18 PM   #146 (permalink)
Gen-1 Insights
John, also in the first picture the suspension is at full droop from being jacked up.
The Following User Says Thank You to The donkey CRX For This Useful Post:
Old 06-04-2014, 10:16 PM   #147 (permalink)
Liberty Lover
j12piprius's Avatar
thanks very much
The donkey CRX, thanks much for the details, and inspiration with your work.
I meant the top/front air strip as regards to the gap, probably explained by being jacked up.
The Following User Says Thank You to j12piprius For This Useful Post:
The donkey CRX (06-05-2014)
Old 06-05-2014, 06:24 PM   #148 (permalink)
Gen-1 Insights
New profile with "Moon" discs on front
Here is the latest addition to the red VX
Detail of the mounting with 4- 6/32 button head bolts into drilled and tapped holes in the wheel
Under the rear skirts are the two one ounce wheel covers made with the 3 mil vinyl
ecoTex (06-05-2014), HHOTDI (06-07-2014), mikeyjd (06-11-2014), OG VX (12-15-2014)
Old 06-05-2014, 06:39 PM   #149 (permalink)
ecoTex's Avatar
green VX - '95 Honda civic VX
90 day: 59.74 mpg (US)
*****in' <--- "female dog" in'
My adjustable WAI / HAI build thread
http://ecomodder.com/forum/showthrea...tml#post408134
The Following User Says Thank You to ecoTex For This Useful Post:
Old 06-05-2014, 06:48 PM   #150 (permalink)
Gen-1 Insights
Thanks Ecotex, Can you change my avatar to this new profile?
