Old 06-05-2014, 08:55 PM   #556 (permalink)
Superfuelgero
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Originally Posted by sarguy01 View Post
LCA bushings without a press? Did you cut them out? I thought about the polyurethane, then decided to go with Moog stock replacement. Did you notice a difference with the poly?
How did you fix the tensioner threads? Helicoil?
I am going to get the car back on the lift and try to simulate the noise. If it is the strut bearings, it should be a fairly simple process. I am hoping it isn't the struts themselves. The KYB's are $350+ for all four. I'd also do the strut bearings as well. That is another $100... But, for the $6,000 I paid for the car, I don't mind some maintenance costs. Used Honda's hold their value well and I am trying to keep this car for a while. I just don't want to dump too much money into it.
Strut mounts will make a horrible racket when they wear out. If its handling fine, and feels tight, that's probably it. When I switched to pillow mounts, I couldn't believe the extra noise from leaving them slightly lose (hard to tighten a air strut center bolt, while its on the car).
Shooting for 600 miles of range at 65-70 mph out of a vx.
